Article ID : 00108368 / Last Modified : 11/02/2015
Can pictures on a memory card be played back through a Blu-ray Disc® (BD) player?
    To play back pictures saved on a memory card though a BD player, the memory card must be inserted in your camera and the camera must connected to the BD player with a USB cable.
    Follow the steps below:
    1. Insert the memory card with images into your camera.
    2. Turn on the camera.
    3. Connect the USB cable from the camera to the USB jack on the BD player.
    4. Turn on the BD player.
    5. Turn on the TV.
    6. Set the TV to the input that you use to watch movies from the BD player.
    7. Use the remote control of the BD player to select the USB input jack to view the pictures from the camera.
    NOTE: Movies recorded in the MP4 format are not supported for playback through a BD player. To playback MP4 movies, connect the camera directly to the TV using the HDMI, multi-terminal or Audio/Video (A/V) cable connection and set the TV to the proper input.
