RAW images recorded using the following models have a resolution of 14 bits per pixel. However, resolution is limited to 12 bits under certain shooting conditions.
ILCE-7 / ILCE-7R / DSC-RX1 / DSC-RX1R
Single-shot shooting *1 | Continuous shooting *2 | BULB shooting | Long Exposure NR is activated *3 | |
Compressed RAW | 14 bits | 12 bits | 12 bits | 12 bits |
ILCE-7M2 / ILCA-99M2 / DSC-RX1RM2
Uncompressed RAW | 14 bits | 12 bits | 12 bits | 12 bits |
ILCE-7S / ILCE-6100 / ILCE-6300 / ILCE-6400 / ILCE-6500 / ILCE-6600
- Silent Shooting: Off
Single-shot shooting *1 Continuous shooting *2 BULB shooting Long Exposure NR is activated *3 Compressed RAW 14 bits 12 bits 12 bits 12 bits
- Silent Shooting: On
Single-shot shooting *1 Continuous shooting *2 Compressed RAW 12 bits 12 bits
ILCE-7RM2 / ILCE-7SM2
Single-shot shooting *1 Continuous shooting *2 BULB shooting Long Exposure NR is activated *3 Compressed RAW 14 bits 12 bits 12 bits 12 bits Uncompressed RAW 14 bits 12 bits 12 bits 12 bits
Single-shot shooting *1 Continuous shooting *2 Compressed RAW 12 bits 12 bits Uncompressed RAW 12 bits 12 bits
ILCE-7RM3 / ILCE-7M3/ ILCE-7RM4
Single-shot shooting *1 Continuous shooting *2 BULB shooting Long Exposure NR is activated *3 Compressed RAW 14 bits 12 bits 12 bits 12 bits Uncompressed RAW 14 bits 14 bits 12 bits 12 bits
Single-shot shooting *1 Continuous shooting *2 Compressed RAW 14 bits 12 bits Uncompressed RAW 14 bits 14 bits
ILCE-9
- Shutter Type: Mechanical Shut
- Shutter Type: Electronic Shut
Single-shot shooting *1 Continuous shooting *2 Compressed RAW 14 bits 12 bits Uncompressed RAW 14 bits 12 bits
ILCE-9M2
*1 “Single-shot shooting”, described above, includes self-timer shooting and interval shooting.
*2 “Continuous shooting”, described above, includes multiple burst shooting under Superior Auto mode, continuous shooting under self-timer mode and continuous bracket shooting.
*3 Long Exposure NR is active when it is set to On and the shutter speed is set to 1 second or longer.
NOTE: JPEG images will be recorded in 8 bits.
