Article ID : 00165348 / Last Modified : 01/12/2016
How to create discs using PlayMemories Home (Windows) / Creatable disc types
    You can create four types of discs using PlayMemories Home: Blu-ray Disc, AVCHD, DVD-Video, and Data disc. Select a disc type to create depending on the optical drive of your computer, image file formats, or players you use to play back.
    For details, refer to the following website.
    The disc types which you can create
    For details on creating discs, refer to the following websites.
    NOTE: The disc creation function is only available for Windows.
