The corner of the image is shaded when using the flash (DSC)
This can happen with compact cameras because there is typically a small distance between the lens and flash.
The combination of a large zoom range, good wide angle capabilities and the compact design of the body can cause flash shading when shooting at short distances.
This is not a malfunction or a reason for repair.
Try to take the image from a greater distance or zoom in a little bit to avoid the shading effect.
