Article ID : 00125016 / Last Modified : 25/05/2022
The AirPlay function is not available after updating the Apple iTunes application.
    If the AirPlay feature of the speaker cannot be found after the Apple iTunes application was updated, your security software or Windows firewall setting may be preventing the Apple iTunes application from communicating.
    Try changing the security settings on your computer, which should then allow playback of your Apple iTunes application using the AirPlay feature.
