How do I know if my camera and/or accessories are compatible?
Use the Accessories Compatibility Information tool
You can easily find compatible models by searching for your product by name or category using the Accessories Compatibility Information tool.
On this page, you'll find compatibility information for the following categories:
Camera body
Interchangeable lens camera, Action Cam, Video recorder, etc. -
E-mount, A-mount, mount adaptor -
Lens accessory
Converter, filter, lens cap, etc. -
Flash / light
Memory card
Memory stick, SD card, CFexpress card, etc. -
Power
Battery, AC adaptor, portable USB charger, etc. -
Other camera accessories
Case, microphone, tripod, etc.
Where to find your product's model name
You can usually find the model name on the bottom of the camera or accessory, or the label on the original box.
Need help understanding the lens name? Check out this article: What do the letters and numbers in the lens name mean?.
