Article ID : 00266107 / Last Modified : 06/01/2022
How to reset the Home Audio System to factory settings
    Before you start
    The steps to reset the Home Audio System to factory settings vary depending on the model. Select the appropriate steps below based on your system's model name.
    If your model name is not listed, please check the manual. Manuals are posted on Sony's support website.
    NOTE: You can find the reset procedure in the Troubleshooting section of the Help Guide or Operating Instructions.
    Resetting the Home Audio System
    IMPORTANT
    • Use the controls on the system to perform the reset.
    • All user-configured settings will be reset to factory default settings.
    CMT-SBT20, CMT-SBT20B
    CMT-SBT40D, CMT-X3CD
    CMT-X5CDB
    GTK-X1BT
    GTK-XB5
    GTK-XB60, GTK-XB90
    GTK-XB7
    GTK-XB72
    MHC-V02, MHC-V21, MHC-V21D, MHC-V42D, MHC-V43D, MHC-V71, MHC-V71D, MHC-V72D, MHC-V73D, MHC-V81D, MHC-V82D, MHC-V83D
    MHC-V11
    MHC-V13
