Article ID : 00152755 / Last Modified : 17/04/2019
How can I check which version of Music Center (SongPal) I currently use?
    To check which version of Music Center (SongPal) you are currently using, follow the below procedure:
    1. In the Speaker & Group screen, tap the drop-down menu icon in the top-right corner of the screen
      Music Center
    2. Select About
      Music Center - About
    3. Your current version will then be displayed as the first menu item
      Music Center - Version
