Video & TV SideView: Discontinuation of EPG and VOD functions
TV Programs and Video on Demand functions offered on Video & TV SideView are now unavailable after the Version 5.0 update. For details, refer to the following questions:
NOTE: Some functions and services may not be supported in certain regions/countries.
Q1 : What functions are unavailable after updating to version 5.0?
Q2 : Can I still use the remote control function after updating to version 5.0?
Q3 : What functions are still available after updating to version 5.0?
Q4 : Is the EPG function of the BRAVIA TV also discontinued ?
Q5 : Can I install this application from Google Play / App Store?
Q6 : Are there any alternatives to the terminated functions?
Q7 : I want to start this application with the remote control function.
A1 : The following functions will be unavailable in Video & TV SideView.
- Top Picks(excluding My Library for Android version)
- TV Program guide
- Timer REC / Reminder
- Video on demand information (YouTube, PlayStation Video, Crackle, watchmi, Zattoo, PPTV, UseeTV and SerialAbTak)
- My program search
- Search TV progs/videos
- My bookmarks
- TV Start Notification (Popular)
A2 : Yes, you can continue to use the remote control function.
A3 : The following functions are still available.
For Android devices
- Remote Control
- My Library
- Mobile device
- Home network
For iOS devices
- Remote Control
- Home network
Q4 : Is the EPG (Electronic Program Guide) function of the BRAVIA TV also discontinued ?
A4 : No, it is not. The TV's EPG functions are expected to continue operating as before.
A5 : You can still install and update the application from the Google Play / App Store.
A6 : Please use the inherent functions of the BRAVIA TV for the EPG and Timer Rec.
NOTE : There are no alternatives to the Timer Rec and the Reminder from the mobile devices.
A7 : Unfortunately, starting the Video & TV SideView application with the remote control function is lo longer supported. You can switch to the remote control function after starting the application.
