Article ID : 00299783 / Last Modified : 20/01/2026Print
Music Center cannot find the DLNA server (computer, etc.)
    Check the following:
    • Check that the smartphone and audio device are connected to the wireless LAN router of the same SSID.
    • If the multicast control is enabled on the wireless LAN router/access point, disable it. For details, refer to the operating instructions supplied with the wireless LAN router.
    • When you use a computer as a DLNA server, check the settings for the computer, software, firewall, and security. When using a Windows computer, you can install Music Center for PC, and change the settings of Music Center for PC.
