Article ID : 00277583 / Last Modified : 22/08/2022Print
New Android 12 software available for Xperia 10 III
    Note! Software updates are released at different times depending on the operator, market, region or country. For this reason, we can't share the exact date when a specific update will be available for your device.
    Software build number
    Xperia 10 III: 62.1.A.0.617
    Updating your device
    Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
    When a software update is available, the Refresh iconrefresh icon appears in the status bar.
    To download and install a system update from the Notification panel
    1. If you are using a device with multiple users, make sure you are logged in as the owner.
    2. Drag the status bar downwards to open the Notification panel.
    3. Scroll down and select the wanted system update, tap the item and then tap UPDATE.
    4. When the download is finished, open the Notification panel again if it is closed, then tap RESTART.
    Why hasn't my device received an update yet?
    Software updates are released at different times depending on the operator, market, region or country. For this reason, we can't share the exact date when a specific update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models
