Can I turn off or disable the Info Banner display on an Android TV or Google TV?
IMPORTANT: This article applies to Android TVs and Google TVs. For other BRAVIA TVs, please refer to How do I disable the info banner on my TV?.
Follow these steps to turn off the Info Banner on your Android TV or Google TV:
- Open the
Settings screen.
- For models released in 2019 or later: use the Quick Settings button:
- On the remote control, press the
(Quick Settings) button.
- Select
(Settings).
- For other models: use the HOME button:
- On the remote control, press the HOME button.
- Select
(Settings).
- The next steps will depend on your TV menu options:
- Select Channels & Inputs → Info banner → set to disable.
- Select Watching TV → Info banner → Hidden or set to disable.
- Select Channels → Info banner → Hidden or Off.
- Select Channel setup → Info banner → Off or set to disable.
The following illustration is an example of a display screen.
