Article ID : 00263088 / Last Modified : 16/06/2021
I cannot access the IPTV app and I get error 22 after the Refresh Internet Content suddenly starts
The services listed in All Apps disappear and cannot perform a software update with an error.
    If you're experiencing this issue, try the following troubleshooting steps:
    1. Perform both an Initialize Personal Information and Refresh Internet Content procedure
    1. Perform an Initialize Personal Information procedure to clear the cached data files:
      1. On the supplied remote control, press the HOME button, and then select Settings.
      2. Select Customer Support.
      3. Select Initialize Personal Information.
    2. Perform a Refresh Internet Content procedure:
      2. Select System Settings.
      3. Select Set-up.
      4. Select Network.
      5. Select Refresh Internet Content.
    If this doesn't resolve the issue, please perform a Factory reset
    2. How to return the TV to Factory Settings
    Before you start:
    • This procedure will return all settings to the default factory values. After completing this process, the initial set-up screen will be displayed.
    • Be sure not to turn the TV off during this process (it takes about 30 seconds), or press any buttons.
    3. Select Factory Settings.
    3. Launch YouTube™ or Maxdome service
    Once all the steps above are done, launch the YouTube or Maxdome service and follow the instructions to perform a software update.
