Article ID : 00260810 / Last Modified : 27/01/2022Print
What to do when Netflix gets stuck on the loading screen?
    If the Netflix app is stuck on the loading screen, try turning your TV OFF and then ON again and relaunch the app. This simple step usually solves most issues.
    If the issue is not resolved, try to Force stop the app and try again.
    To Force stop the Netflix app
