Article ID : 00257768 / Last Modified : 22/02/2021
Recent apps sometimes disappear from the Input menu
    Follow these steps to make sure an app you use frequently is displayed in the Input screen:
    1. On the TV remote control, press the Input button.
    2. Press the Right arrow button to select Edit.
    3. Select the app you want to show, then select Close.
