Article ID : 00252670 / Last Modified : 30/08/2021Print
What are the differences between Catalyst Browse, Content Browser, and RAW Viewer?
    You can find the function comparison table of the clip management tool, Catalyst Browse, that will replace Content Browser and RAW Viewer on the following pages:
    English: https://www.sonycreativesoftware.com/catalystbrowse/compare
    German: https://www.sonycreativesoftware.com/de/catalystbrowse/compare
    French: https://www.sonycreativesoftware.com/fr/catalystbrowse/compare
    See the system requirements below the function comparison table for the operating environment of Catalyst Browse.
    You can use Catalyst Browse by installing it and then registering as a user.
    You can find functions and the operating environment of RAW Viewer on the following pages:
    English: https://www.sonycreativesoftware.com/rawviewer
    German: https://www.sonycreativesoftware.com/de/rawviewer
    French: https://www.sonycreativesoftware.com/fr/rawviewer
    Spanish: https://www.sonycreativesoftware.com/es/rawviewer
    Italian: https://www.sonycreativesoftware.com/it/rawviewer
