Troubleshoot Truly Wireless headphones Sound issues (no sound, or sound only from one side)
This page introduces how to troubleshoot for Truly Wireless headphones Sound issues: No sound, sound is only heard from one side.
Follow these steps to troubleshoot this issue:
Before you start
Updating the headphones software to the latest version may resolve the issue. Perform the update before going to the next step.
WF-1000X
WF-1000XM3
WF-H800
WF-SP700N
WF-SP800N
WF-SP900
If the following situations seem to cause the issue, clean the mesh sheet with gentle running tap water.
- Foreign substances (such as earwax) build up in the headphone sections.
- Water gets inside the headphone sections.
For information on how to maintain and clean the player after sports (swimming or running, etc.), refer to the Help Guide.
WF-XB700
Solution
Does the power indicator flash when you remove the headphones from the charging case?
- Yes, the indicator flashes.
- Go to step 3.
- No, the indicator does not flash.
- Go to step 2.
After charging, do the headphones turn on and produce sound?
Connect the charging case to an AC outlet, and then set the headphones in the charging case.
NOTE: Be sure to charge the charging case as well as the headphones.
- Yes, the headphones produce sound.
- The issue was caused by a low battery level in the headphones.
- The headphones turn on, but they do not produce sound.
WF-1000X:
If the sound is not produced from the right unit, refer to the Sound cuts out or no sound comes out of the right unit of the headset article.
If both earbuds have no sound, or if the issue is not resolved, go to step 3.WF-1000XM3:
Go to step 3.WF-H800:
Go to step 3.WF-SP700N:
If both earbuds have no sound, or if the issue is not resolved, go to step 3.WF-SP800N:
Go to step 3.WF-SP900:
If the sound is not produced from the right unit, refer to the Right unit of WF-SP900 does not produce sound article.
If both earbuds have no sound, or if the issue is not resolved, go to step 3.WF-XB700:
Go to step 3. - No, the headphones do not turn on.
- The headphones may not have charged correctly.
Refer to the Troubleshoot why the Truly Wireless headphones are not charging article.
Do the headphones produce sound when you reconnect the headphones with the playback device?
Try the following procedure:-
Set the headphones in the charging case, and then close the lid.
Connect the headphones with the playback device.
- There was a temporary connection issue with the playback device.
- No, the headphones do not produce sound.
- Go to step 4.
Do the headphones produce sound when you increase the volume on the headphones or the playback device?
- The issue was caused by a low volume. Adjust the volume to an appropriate level.
- Go to step 5.
Do the headphones produce sound after resetting?
Refer to the following to reset the headphones.NOTE: For WF-SP900, restart the headphones and check to see if the headphones turn on.
WF-1000X
WF-1000XM3
- Visit the Help Guide or view the video on how to reset the headphones.
WF-H800
- See the Resetting the headset section in the How to reset or initialize the headset article or view the video on how to reset the headphones.
WF-SP700N
WF-SP800N
WF-SP900
WF-XB700
- See the Resetting the headset section in the How to reset or initialize the headset article.
- The issue was caused by a temporary malfunction of the headphones.
- Go to step 6.
Do the headphones produce sound after initializing and pairing with the playback device?
Refer to the following to initialize the headphones.NOTE: All of the data (music files, pre-installed data, etc.) saved to the main memory of the headphones will be erased.WF-1000XM3
Initialize the headset to restore the factory settings. Visit the Help Guide or view the video on how to initialize the headphones.
WF-H800
- Initialize the headset to restore the factory settings. See the Initializing the headset section in the How to reset or initialize the headset article or view the video on how to reset the headphones.
WF-SP800N
WF-SP900
WF-XB700
- Initialize the headset to restore factory settings. See the Initializing the headset section in the How to reset or initialize the headset article.
- There was a connection issue with your playback device such as the disconnection of the Bluetooth pairing.
- Go to step 7.
Do the headphones produce sound when connected to another playback device?
Connect your headphones to a different device, such as a smartphone or Walkman player.- Yes, the headphones produce sound.
- There may be an issue with the playback device you previously connected the headphones to.
- The headphones may be malfunctioning. Service may be required.
