Article ID : 00246876 / Last Modified : 18/06/2020
Notice of Replacement program for some SD memory cards of SF-M series, SF-M series TOUGH specification, and SF-G series TOUGH specification
    Thank you for your interest in Sony products.
    We have identified an issue with some SD memory cards from the SF-M series, SF-M series TOUGH specification and SF-G series TOUGH specification.
    VSC mode data issue
    When using a camera* compatible with VSC mode (Video Speed Class), recorded footage data on the card may be damaged or may have not recorded optimally.
    * Cameras compatible with VSC mode with V60/V90.
    To address this issue, we are implementing a free replacement program for affected SD memory cards.
    Applicable models
    You can identify your card using the model number on the front of the card as indicated with a circle in red.
    SF-M series
    Note! Applicable cards can be
    identified only if you see
    “V60”, “R:277MB/s” and “W:150MB/s”
    on the front of the card.
    • SF-M64
    • SF-M128
    • SF-M256
    • SF-M64T
    • SF-M128T
    • SF-M256T
    • SF-G32T
    • SF-G64T
    • SF-G128T
    How to check if your card is affected
    SF-M series
    1. Identify that you have an applicable card. SF-M series cards can be identified with V60, R:277MB/s and W:150MB/s printed on the front.
    2. Inspect the back of your card and see if a star mark/asterisk (*) is added on the bottom left corner.
      1. If YES, your card is not affected by this issue.
      2. If NO, your card is affected by this issue.
    Affected card
          Affected card
    Card not affected
    1. Inspect the back of your card and see if a star mark/asterisk (*) is added on the bottom left corner.
    Affected card
    Card not affected
    There are two ways to see if your card is affected by this issue.
    a. If YES, your card is not affected by this issue.
    b. If NO, please see the following step.
        2. Inspect the back of your card and see if the alphanumeric code begins with TV or TR.
    a. If the alphanumeric code begins with TR, your card is not affected by this issue.
    b. If the alphanumeric code begins with TV, your card is affected by this issue
    Affected card
    Card not affected
    Card not affected
    We are offering free replacements for affected SD memory cards from June 18, 2020, until Mar. 31, 2022.
    You can request an SD card exchange via the following request forms:
    IMPORTANT: We cannot transfer the contents from your affected SD memory card to the replacement card. Please create a backup of your contents to a computer or other storage device before sending the card for replacement.
    *As a result of the ongoing COVID-19 situation, some of our services may be impacted. While we will try to minimise this, delays may occur. We apologise for any inconvenience this may cause and seek your kind understanding during this challenging period.
