Article ID : 00245354 / Last Modified : 03/11/2020
A picture while holding the product in your hand is needed to make your claim valid
    To make sure your claim is valid, we need a picture of your product sticker while you hold the product in your hand
    Instructions:
    • Take the picture while holding the product in your hand, clearly showing the full serial number sticker. Your hand should be visible too.
    • Make sure to show the sticker with the serial number and model name. For lenses, in case you do not manage to put the serial number and the model name in one picture, please upload two separate pictures as we need both items to validate your claim. There are 3 upload entries on the personal details page. The first one is to upload your invoice, the second one is for the serial number of your product and the third one can be used in case model name and serial number do not fit into one picture.
    • When you take the picture of your product sticker(s), please make sure that:
      • it is not blurry
      • it is taken under good light conditions
      • your hand is visible on the picture too
      • and the full sticker is visible.
    Examples
    Example 1
    Example 2
    A picture like this will not be accepted:
