I can't remove the cover from my mobile device
Remove the cover from your device as shown below.
- XQZ-CVAT, XQZ-CVAU, SCVI10, SCTI30, SCTH70, SCSH70
- Detach the bottom right corner of the device from the casing, then detach the bottom left corner.
- SCSI10, SCSI20, SCSH30, SCSH40
- Detach the upper right corner of the device from the casing, then detach the bottom right corner.
