Article ID : 00238775 / Last Modified : 13/04/2023Print
Noise occurs when pressing the play/pause button.
    Since the Vinyl Processor feature is a sound quality setting that reproduces the acoustic phenomena peculiar to vinyl (analogue) records, the following can occur when that feature is turned on in the Sound adjustment   screen.
    • While playing content, even if the content is silent, it may be output with added noise.
    • Noise is heard when pressing the play/pause button.
    • Noise is heard when the Vinyl Processor feature is turned on or off.
    If you are concerned about noise, we recommend not using the Vinyl Processor feature.
