I cannot use Apple CarPlay or Android Auto.
Follow these instructions to resolve the issue:
- Reboot your mobile device.
- Use a different USB cable to connect your mobile device and the unit and check if the issue is resolved.
- If you're using a long USB cable, try using a shorter cable.
