Apps added to the home screen won't start when tapped
The apps added to the home screen through Settings > Add Apps may not start when tapped after you update the App Remote for Android to Version 2.2.1. Follow these steps to access the apps:
- On your smartphone, open the App Remote app.
- Select Settings.
- Select App Control by Voice.
- Register the apps that won't start through the following options:
- Navigation App Menu
- Phonebook App Menu
- Audio App Menu
- Video App Menu
