Article ID : 00186439 / Last Modified : 29/09/2017
How do I change back the TV app to the default app?
    Perform one of the following procedures so that the default app launches.
    Uninstall the added app.
    1. Press the Home button on the remote control.
    2. Select Settings.
    3. Select Apps in the TV category.
    4. Select the added app from Downloaded apps.
    5. Select Uninstall.
    6. Select OK.
    Change the settings so that the default app launches.
    2. Select Settings.
    5. Select Clear defaults.
    6. Select OK.
    7. Watch TV after performing the settings above. When a dialog is displayed, select OnAir, and then select Always.
