Article ID : 00182870 / Last Modified : 26/02/2020
Timeline for the changes to Digital terrestrial television (DTT) channel numbers – 21st February 2020
    Due to Ofcom changing its broadcast licence to Com8, the transmitters used for the Com8 network will receive maintenance over the coming months.
    As similar broadcast boundaries exist between the two—and to minimise overall disruption to the network—the change in the broadcast signal will also coincide with the 700 MHZ clearance programme.
    How will this affect me?
    As a result, in order to view certain DTT channels/programmes, you may need to retune/scan your TV. For model-specific information on the retuning procedure, please see the following article:
    Rollout plan overview
    The Com8 rollout plan is scheduled to take place across the UK from 10th February – 1st May 2020.
    NOTES:
    • If certain channels are still missing after retuning your TV, they may have been removed by the broadcaster/network provider.
    • For an up-to-date list on the areas in transition and planned engineering works, please visit the Freeview support website.
    Timeline for the changes to Digital terrestrial television (DTT) channel numbers - 26th July 2017
    Due to Ofcom's decision to reallocate some frequencies currently used for DTT to mobile phone services, Freeview transmissions found in the 700MHz ultra high frequency (UHF) band will be moved. This process, known as the 700MHZ Clearance Programme, will roll out across the UK starting from Q3 2017, and will be completed in 2020.*
    As a result, in order to view certain DTT channels/programmes, you will need to retune your TV and may have to replace your antenna well. For model specific information on the retuning procedure, please see the following article:
    Area transmitter name Date
    Keelylang HillQ3 2017
    Rumster ForestQ3 2017
    RosemarkieQ3 2017
    KnockmoreQ3 2017
    EitshalQ3 2017
    BressayQ3 2017
    Torosay Q4 2017
    MidhurstQ1 2018 | Q4 2019
    The WrekinQ1 2018
    Ridge HillQ1 2018
    Sutton ColdfieldQ1 2018
    Crystal PalaceQ1 2018
    Sandy HeathQ2 2018
    RowridgeQ2 2018
    OxfordQ2 2018
    HanningtonQ2 2018
    TacolnestonQ2 2018
    SadburyQ3 2018
    DurrisQ3 2018
    Black HillQ3 2018
    DarvelQ3 2018
    SudburyQ3 2018
    Bluebell HillQ3 2018
    HeathfieldQ3 2018
    CraigkellyQ4 2018
    LlanddonaQ4 2018
    BlaenplwyfQ4 2018
    PreselyQ4 2018
    Moel Y ParcQ1 2019
    Stockland HillQ1 2019
    Beacon HillQ1 2019
    Fremont PointQ1 2019
    WenvoeQ2 2019
    MendipQ2 2019
    Huntshaw CrossQ2 2019
    Caradon HillQ2 2019
    RedruthQ2 2019
    SelkirkQ3 2019
    CaldbeckQ3 2019
    CarmelQ3 2019
    LimavadyQ3 2019
    DivisQ3 2019
    Brougher MountainQ3 2019
    AngusQ4 2019
    ChattonQ4 2019
    Pontop PikeQ4 2019
    BilsdaleQ4 2019
    DoverQ4 2019
    Emley MoorQ1 2020
    BelmontQ1 2020
    Isle of ManQ2 2020
    Winter HillQ2 2020
    NOTES:
