Installation instructions for Wall mount bracket SU-WL450
Match your wall mount to the right manual
Sony makes a universal wall mount that's designed to work across our whole TV range. Though the SU-WL450 bracket is the same, different instructions are provided for the various TV models.
Having a TV mounted on a wall is a big job. It should be done carefully, and only if you're confident you can do it correctly. If you're in any doubt we recommend you have your Sony TV professionally mounted by a dealer or licensed contractor. If your TV is large, we strongly recommend you use professionals.
Click over the link to download the manual:
Download link |
Applicable model |
· KD-43XD8005 · KD-43XD8077 · KD-43XD8088 · KD-43XD8099 · KD-43XD8305 · KD-49XD8005 · KD-49XD8077 · KD-49XD8088 · KD-49XD8099 · KD-49XD8305 · KD-55XD8005 |
· KD-65XD8599 · KD-65XD8505 · KD-65XD8577 · KD-55XD8505 · KD-55XD8577 · KD-55XD8588 · KD-55XD8599 |
· KD-75XD9405 · KD-65XD9305 · KD-55XD9305 |
· KD-65XD93xx · KD-55XD93xx |
· KD-65ZD9 | |
· KD-49XD70xx · KD-55XD70xx · KD-49XD75xx · KD-55XD75xx · KD-65XD75xx |
KDL-32WD750 |
Download link |
KD-43X8301C · KD-43X8305C · KD-43X8307C · KD-43X8308C · KD-43X8309C · KD-49X8301C · KD-49X8305C · KD-49X8307C · KD-49X8308C · KD-49X8309C · KD-55X8501C · KD-55X8505C · KD-55X8507C · KD-55X8508C · KD-55X8509C · KD-65X8501C · KD-65X8505C · KD-65X8507C · KD-65X8508C · KD-65X8509C · KD-75X8501C |
· KD-55S8005C · KD-55S8505C · KD-65S8005C · KD-65S8505C |
KD-55X8005C · KD-49X8005C |
· KD-55X9305C · KD-65X9305C |
· KDL-43W755C · KDL-43W756C · KDL-43W805C · KDL-43W807C · KDL-43W808C · KDL-43W809C · KDL-50W755C · KDL-50W756C · KDL-50W805C · KDL-50W807C · KDL-50W808C · KDL-50W809C · KDL-55W755C · KDL-55W756C · KDL-55W805C · KDL-55W807C · KDL-55W808C · KDL-55W809C |
· KDL-65W855C · KDL-65W857C · KDL-65W858C · KDL-65W859C |
· KDL-32W705C · KDL-40W705C · KDL-48W705C |
KDL-32R413B · KDL-32R415B · KDL-32R430B · KDL-32R433B · KDL-32R435B · KDL-40R450B · KDL-40R453B · KDL-40R455B · KDL-40R480B · KDL-40R483B · KDL-40R485B · KDL-40W605B · KDL-48W585B · KDL-48W605B |
KDL-60W605B | |
· KD-65X9005B · KD-55X9005B |
· KDL-55W828B · KDL-55W829B |
