Article ID : 00172097 / Last Modified : 06/03/2017
How to add an application to or delete an application in the FAVORITES category of the Opera TV Store
Follow the procedures below.
How to add an application to the FAVORITES category
  1. Access the Apps category located at the left side of the sub-menu screen.
  2. Choose the application that you want to add and press the Enter button.
  3. Navigate down to the FAVORITES  tab and press the Enter button.
  4. Return to the Opera Home screen and you will see the FAVORITES tab appear at the left side of the sub-menu.
    NOTE: When you cannot find the application you have added to the FAVORITES category, check whether the application has been installed correctly by using the Search menu on the bottom left of the Opera TV Store. If you still cannot find the application, install the application again.
How to delete an application in the FAVORITES category
  1. Access the FAVORITES category located at the left side of the sub-menu.
  2. Choose the application that you want to remove and press the Enter button.
  4. The application will be removed.
NOTE:
  • FAVORITES of the Opera TV Store has no feature that will allow you to rearrange or change the order of the applications that you have installed.
  • FAVORITES of the Opera TV Store has no limit on the number of installing applications.
