Abnormal noise flicks is heard from the device
When I turn on or off the device, an abnormal noise flicks is heard from the device.
Since it is the sound when the TA-ZH1ES operates, it is not a failure.
In the following cases, the operation sound (switch sound) inside the device can be heard as flicks.
- When setting OUTPUT to PRE OUT.
- When turning the device on or off.
- When switching INPUT.
- When setting to mute.
- When a song is changing.
