Article ID : 00164091 / Last Modified : 30/01/2018
The Multi-selector in ILCA-99M2 does not work fine or has difficulty to control
    • For precise and smooth manipulation, it is recommended to push the selector outward from the centre.
    • Pushing it from the outside to the centre (inward motion) will not have the same smooth result
    • Also, please refer to the Help Guide.
          Image       Recommended
     Push from the centre to the outer side
     Not Recommended
     Push from the outside to the centre
