Article ID : 00163389 / Last Modified : 18/11/2016
When TalkBack is turned on, focus does not move correctly
When TalkBack is set to On, the focus (selection box) may not work correctly.
In this case, use Screen reader instead of TalkBack.
Perform the following procedure.
  1. Press the HOME button on the remote.
  2. Select Settings.
  3. Select Accessibility in the System Preferences category.
  4. Select Services.
    1. Select Screen reader, then set to On.
    2. Select TalkBack, then set State to Off.
