Article ID : 00163447 / Last Modified : 18/11/2016
When the TV starts up, the sound is not at the volume set in On timer
Volume Setup in On timer is the function that controls the volume of the TV speaker.
If an HDMI-CEC compatible AV Receiver/Soundbar is connected to the TV, you cannot set the volume of the connected device from On timer of the TV.
If you want to set the volume of the connected device at the time of TV start-up, adjust the desired volume by pressing the volume buttons on the remote, then turn off the power.
