Can I bundle all cables together in the cable holder of the TV stand?
Yes, you can. However, please keep in mind that depending on the size of your cables, not all cables may fit into the holder when bundled.
The following diagram is an image showing the cable holder in use.
NOTE: Affected Panel Sizes are 32, 40 and 48 inches.
