Article ID : 00148974 / Last Modified : 27/06/2019
Can DSEE HX be used with High-Resolution (Hi-Res) audio files?
    The DSEE HX setting can be turned on while playing a Hi-Res audio file but there is no effect on the audio quality.
    NOTES:
    • The DSEE HX setting can be used on files that have a sampling frequency of 48 kHz or less. For further details about the sampling frequency, check the specifications or supplied operations guide.
    • When the DSEE HX setting is set to OFF, the car stereo system will automatically check whether the files are suitable for playback.
