Article ID : 00140742 / Last Modified : 21/01/2016
When the Table-Top Stand is in the middle position, where can I attach a tether to prevent the TV from tipping ?
    The Stand plates that you use when the Table-Top Stand is in the middle position contain screw holes for attaching a tether. Align the tether with these holes and attach it with screws.
    When attaching a tether that prevents the TV from tipping, be aware that the tether and screws are not included. Use M5 screws in the holes on the Stand plates.
