Article ID : 00129146 / Last Modified : 30/01/2018
YouView: Recording and On Demand
    Recording
    Can I record channels using YouView mode on my Sony TV?
    If I connect an external hard drive to my Sony TV, can I record channels using YouView?
    Can I use the Red Button services?
    Why can't I access the BBC Red Button+ service?
    On Demand
    What On Demand players are available through YouView on my Sony TV?
    Can I get Internet Channels on a YouView enabled Sony TV?
    Where is the milkshake! Player?
    I can’t see the ITV Hub, All 4, S4C or STV Players
    Currently you are not able to record channels using YouView. To see what features are available on a YouView enabled Sony TV, please see:  What features does YouView offer on a Sony TV?
    Currently you are not able to record channels using YouView onto an external hard drive. To see what features are available on a YouView enabled Sony TV, please see:  What features does YouView offer on a Sony TV?
    Yes. You can use the red button on YouView just like any other digital TV.
    If you are unable to access the BBC red button service please see the article: Why can't I access the BBC Red Button+ service?
    If you cannot access the BBC Connected Red Button Service, please check the following:
    • Check your Aerial is connected to your TV
    • Check your TV is connected to the Internet. If you’re unable to connect to the Internet then see the article: Connecting to a network on your Sony's Android TV
    • Make sure you are trying to access the service from one of the ‘on-air’ BBC channels. If the channel is ‘off-air’ the Connected Red Button service will not be available. Try using another ‘on-air’ BBC channel
    • If you have passed all these checks, then please try and reboot your TV. To do this press and hold the standby button on the remote for 8 seconds. The TV will then power down. Once it is off, turn it back on
    Here is a list of the available On Demand players available through YouView on a Sony TV:
    • BBC iPlayer
    • ITV Player
    • All 4
    • Demand 5 (including milkshake! programmes)
    • STV ** (available from 27th October 2016)
    No, currently you can only watch freeview channels in the guide. If your broadband provider offers Internet channels as a part of a TV subscription package, you'll need to contact your Internet service provider (ISP) directly.
    If you are using YouView through a Sony TV, then the milkshake! Player can be found in the Demand 5 Player.
    If you can’t see any of these players, please check your cables are connected correctly, especially the aerial lead from the aerial socket in your home to the back of your TV. This requirement is necessary to receive all of YouView's services. Then re-tune your channels by going to the following menu:
    [Settings] > [TV Signal & Quality] > [Re-tune Channels].
    To see all the players available in your area, please put your address details in the Availability Checker, and see the On Demand section.
    **NOTE: The STV Player is available in Scotland only. However, regions that border England and Scotland that can receive both transmissions may be affected.
    If you are still not able to see the players, please check YouView's useful contact support page.
