Article ID : 00122892 / Last Modified : 07/06/2017Print
How can I check the data size of an app that has finished installing?
    Please follow the steps below:
    1. Using the supplied remote, press the HOME button.
    2. Select Settings.
    3. Select Apps in the TV category.
    4. Select Downloaded apps.
    5. Check the data size displayed under the name of the corresponding app.
