Article ID : 00120824 / Last Modified : 10/06/2015
Where can I purchase an additional attachment ring for my Smart Tennis Sensor (Wilson, Prince, Yonex or Head)?
    You can order attachments from the EET Europarts website, our official partner.
    Please make a search in the "Find products here" search box using the following part name:
    • ATT-SO1 for Wilson, Prince, and Yonex rackets
    • ATT-HD1 for HEAD rackets
    Then, select "BUY" and follow the on-screen instructions to place your order.
    Also, please make sure to check that your racket is indeed compatible with the Smart Tennis Sensor, by visiting this racket compatibility page.
