Article ID : 00120447 / Last Modified : 12/07/2018
What remotes are compatible with Sony's Android TV?
There are two official remotes for the EU region that are compatible with Sony's Android TV, the standard infrared remote and the Touchpad remote.
Standard IR remote
Section 1
  • Source / input button: Displays and selects the input source
  • Sync Menu: Initiate  Bravia Sync
  • Power / TV standby button: Turns the TV on or switches to standby mode
  • Digital / Analog: Toggle between Digital and Analog input
  • TV / Radio: Toggle between TV and Radio signal
  • Football button: Turn Live Football Mode on or off
Section 2
  • Numbered buttons (1 to 0): Select channels. For channel numbers 10 and above, enter the next digit quickly
    • In text mode, enter the three digit page number to select the page
  • Exit button: Return from the previous screen or exit the menu
  • Text button: Displays text broadcast
ImageSection 3
  • Coloured buttons: Access certain functions (based on the app, service or service currently in use)
  • i+/? (Information / text reveal button): Displays information. Press once to display the information about the programme / input you're viewing. Press again to remove the display from the screen:
    • In text mode, reveals hidden information
  • Netflix button: Press to access "Netflix" online service:
    • NOTE: The Netflix button is replaced with TV button if Netflix is not available in your region
  • Help: Open the Help option
Section 4
  • Action Menu: Opens the quick menu guide showcasing the most popular actions / functions for your TV
  • Guide button Open up the electronic programme Guide (EPG)
  • Home button: Return to Home screen or cancel the current menu
  • Discover button: Opens the Content Bar to search for content
  • Back button: Go back to previous screen / option
  • TV button: Watch TV
  • Item select (arrows) / Enter buttons:
    • Select or adjust items
    • Confirm selected items
Section 5
  • Volume +/- buttons: Adjusts the volume
  • Jump button: Returns to the previous channel or input viewed more than 15 seconds ago. Alternate between the current channel or input and the last channel or input that was selected.
  • Mute button: Mute the sound. Press again to restore the sound
  • Prog buttons: Select the next or previous channel
  • In text mode, select the next and previous page
Section 6
  • Audio button: Select the sound of multilingual source or dual sound for the programme currently being viewed (depends on programme source)
  • Subtitle button: Changes the subtitles settings
  • Widescreen button: Change the screen display. Press repeatedly to change the ratio
Section 7
  • Rewind /Play / Fast forward / Skip back / Pause / Skip forward / Stop buttons: Operate media content on the TV, and on connected Bravia Sync compatible devices
  • REC: Activate  HDD REC function
  • NOTE: The message "To use this feature, a system software update is required. For details, please refer to Reference Guide" may be displayed if you don't have the latest software installed.
  • Title list button: Access the title list of recorded titles on HDD recording
 Touchpad remote
Section 1
Section 4
  • Action menu: Opens the quick menu guide showcasing the most popular actions / functions for your TV
  • Home button: Return to Home screen or cancels the menu
Section 5
  • Prog buttons: Select the next and previous channel:
Section 8
Section 9
  • Touchpad area: Navigate to the different menus on your TV using the touch sensitive area
Section 10
  • NFC button: (NFC) Touch the device (e.g. some models of Xperia) corresponding to the One-touch mirroring function, then its screen is displayed on the TV
NOTE: The button layout of your remote may differ depending on your region.
