Article ID : 00158664 / Last Modified : 19/09/2017
Can I charge my Apple mobile or portable device using the speaker?
Yes, you can charge an Apple iPad, iPhone or iPod using the speaker. Charging automatically starts when you connect the Apple device to the USB port of the speaker while it is connected to an AC outlet.
NOTES:
  • You can charge the Apple device even if the speaker is turned off.
  • If the speaker is being powered by the built-in battery, the Apple device can be charged only when the speaker is turned on.
  • For SRS-X9, SRS-X99 and SRS-BTD70, charging is only supported when the Apple device is connected via the USB-A port.
