Notice of system update for Digital Photo Frame DPF-WA700 / DPF-W700
As of April 30th, 2015 certain features will no longer be available when using Facebook in the DPF-WA700 / DPF-W700 Digital Photo Frame, due to specification changes made by the service provider. A system update is being prepared for release in late May, in order to restore some of the features.
NOTE: Certain features will change after the system update, in accordance with the specification changes made by the service provider.
Affected features - as of April 30th, 2015 until the system update is implemented:
- You will not be able to receive friend's photos.
- However, you will be able to receive photos in which you are tagged (but the sender's name cannot be received).
- You will not be able to use "Like".
After implementation of the system update (scheduled for late May):
- However, you will be able to receive photos in which you are tagged, and photos from friend's who use the DPF-WA700 / DPF-W700.
NOTE: "Friends" refers to users who you have registered as friends on Facebook
As of 4/30/2015 to system update | After system update | ||
Login | Yes | Yes | |
Check for new photos | Your own photos | Yes | Yes |
Friends' photos | Can only receive photos in which you are tagged | Can only receive photos in which you are tagged and photos from other customers who use the DPF-WA700/W700 | |
Tagged photos | Photos can be received, but not the sender's name | Photos and the sender's name can both be received | |
Select friends from whom you wish to receive photos | No | Restricted to customers who use the DPF-WA700 / DPF-W700 | |
Display comments | Yes | Yes | |
Like | No | Yes |
