Article ID : 00124632 / Last Modified : 28/01/2019
4,096 x 2,160 p format does not display at full-scale.
    Information is different depending on the Android version of your TV.
    For Android OS5(L) and OS6(M):
    This is a specification of the TV.
    Change the output signal of the source device to 3,840 x 2,160 p.
    For Android OS7(N):
    To display at full-scale, perform the following procedure.
    1. Press the ACTION MENU on the remote control.
    2. Select Wide mode in the Display & Sound category.
    3. Select Full 1 or Full 2.
