Article ID : 00107650 / Last Modified : 24/08/2017
Can the Zoom (multi-stage variable speed) be used when SELP18200 lens is used with a Remote Control Tripod?
    It can be used if the camera is compatible with the Remote commander pan handle of the tripod.
    The available functions differ on each model.
    When using NEX-VG30
    The zoom speed can be changed on the camera by setting the Zoom Speed function to Variable or Fixed.
