Article ID : 00106248 / Last Modified : 31/07/2017
How to reset the TV to the original factory settings?
Reset the TV to the original factory settings.
    1. On the remote, select MENU.
    2. The menu displays on the TV.
    3. Use the left/right/up/down button on the remote to select Settings >  Set-up > Factory Settings
    4. You will be prompted with a message "Do you want to restore Factory Settings?".
      Select OK to reset all settings to factory settings.
      Note: After completing this process, the initial set-up screen is displayed.
      Select Cancel to return to previous menu.
