Can I manage Libraries (music, etc.) separately for each computer user with Media Go?
Media Go allows you to manage Music Library for every user account.
Add a personal folder for each user account to the Media Go Library.
You cannot browse an individual folder for a user unless you are logged onto the computer with that user account.
- Click File - Add/Remove Media from Library... in the menu at the top of the Media Go screen.
- Click Add Folder... and add the individual folders for each user account.
- Click OK.
NOTE: A list of devices supported for use with the Media Go software is available at: http://mediago.sony.com/enu/supported-devices/.
The Media Go software may also work with other devices not on this list. However, we cannot guarantee operation if they are not listed.
