Article ID : 00103707 / Last Modified : 22/12/2014
Can I convert audio file formats using Media Go?
Music content transferred to Media Go can be converted to AAC, MP3, or FLAC.
Try the following procedures:
  1. Select the song whose format you want to convert from the Library.
    NOTE: If you want to convert a song stored on your Walkman, transfer the song back to Media Go.
  2. Select Tools - Convert File... in the menu displayed at the top of the screen.
  3. In the Convert File screen, display the Format pull-down menu, select the desired file format from AAC, MP3, or FLAC and then click Convert.
NOTE: A list of devices supported for use with the Media Go software is available at: http://mediago.sony.com/enu/supported-devices/.
The Media Go software may also work with other devices not on this list. However, we cannot guarantee operation if they are not listed.
