Article ID : 00164759 / Last Modified : 30/11/2016
How to set Parental Control for Netflix movies
    This article is designed to assist with setting the Parental Control settings when using the Netflix app on a Sony device. Prior to using this solution, understanding the following is recommended.
    If using Netflix version 3:
    You can restrict TV shows and movies for kids 12 and under directly on device by follow these steps.
    1. With the Netflix app open, select HOME.
    2. Select Switch and manage profiles.
    3. Select the Pen symbol to edit the profile you would like to put the restriction on.
    4. Check the tick box next to For Kids.
    If using Netflix version 2:
    Maturity levels can be set to individual profiles. This can only be done through the Netflix web site. Visit the Netflix help centre for additional information on how to set parental controls on the Netflix account.
    NOTE: Restricting TV shows and movies for kids 12 and under directly on device is not supported.
    If using Netflix version 1:
    This version of the Netflix app is limited to the parental settings of main top profile regardless of whether there are other profiles or not.
    NOTE: As part of the Netflix operations, the main top profile cannot be deleted from the list of profiles on the Netflix web site.
