If your BRAVIA television is a 2013, or older, model, the maximum file size supported is up to 2 GB.
If your BRAVIA television is a 2014, or newer, model, the maximum file size supported are as follows:
File System |
Max File Size |
Max hard drive size |
FAT16 |
2 GB |
Not supported |
FAT32 |
4 GB |
2 TB |
exFAT |
16 TB |
16 TB |
NTFS |
16 TB |
16 TB |
NOTE: Sony cannot ensure the compatibility between BRAVIA and non-Sony USB device.
