Article ID : 00096773 / Last Modified : 22/01/2019
How do I move the Screen Key Pad from top to bottom or vice versa?
Using the Touchpad remote control
  1. Press the Control Bar to display the Screen Key Pad.
  Control Bar
   2.   Press the center of the Touchpad for 3 to 5 seconds to move the position of the Screen Key Pad.
Touchpad
Using the IR (infrared) remote control
  1. Press the KEY PAD button to display the Screen Key Pad.
  2. Press the Enter or Select button for 3 to 5 seconds to move the position of the Screen Key Pad.
