How do I move the AF range frame when shooting with Flexible Spot ?
The position of the AF range frame can be adjusted only when the Flexible Spot setting is displayed, which closes when the shutter is released. You can recall the display by following the steps below.
- On the camera, press the MENU button.
- Select Focus Area.
- Select Flexible Spot.
NOTE: You can adjust the position or size of the AF range frame once the Flexible Spot setting is displayed.
If you assign Standard to the centre button of the control wheel, the Flexible Spot function is assigned to the centre button. By doing so, the Flexible Spot setting is displayed just by pressing the centre button. Follow the steps below to assign Standard to the centre button of the control wheel.
- Select Custom Settings.
- Select Custom Key Settings.
- Select Center Button.
- Select Standard.
