Article ID : 00078276 / Last Modified : 27/06/2019
What are the differences between HS120, HS100 and SSLOW?
Although the three have the same frame rate, their recording formats are different.
SSLOW
  • Super slow recording
  • Movies shot at a 120p/100p frame rate are recorded at 30p/25p
  • No audio is recorded
HS120/HS100
  • High speed recording
  • Movies are recorded at a 120p/100p frame rate
  • Audio is recorded
NOTES:
  • It is possible to edit and play back high-speed recorded movies in slow motion using the Action Cam Movie creator.
  • You can create impressive movies with sound (or no sound) by combining normal-speed and slow-speed sequences inside one movie.
